All current orders of Periscopes and Tow Rope sets that incorporate these eye bolts will now come with the new eye bolts.
Prices
Gent11-10 1-72 Thread Machine Turned Eye Bolts in Brass x 10 $25.00
Gent11-1 1-72 Thread Machine Turned Eye Bolts in Brass x 1 $3.00
As 1-72 scaled nuts are not readily available worldwide I will include nuts with Eye Bolt orders at the following prices.
Gent11-N10 1-72 Brass Scale Hex Nuts x 10 $2.50
Gent11-N1 1-72 Brass Scale Hex Nut x 1 $0.25
The following cast Wing Nuts fit the Eye Bolts.
Gent010A Wing Nuts size 1.72 Thread Qty 10 (cleaned ready to use) $20.00
Gent010B Wing Nuts size 1.72 Thread Qty 10 (on tree) $15.00
The wing nuts have the thread cast into them but the thread does require cleaning with a 1-72 tap if you order item Gent10B. Item Gent10A are tapped ready to use.
I have around 140 of the old investment cast eye bolts, rather than throw them away I am offering them at $1.00 each just to cover my casting cost. These will be on the tree and require clean up. If you would like to order some of these refer to Gent12B Cast Eye bolts.
The following items are removed from stock.
Gent011a Eye Bolts 1.72 Tread 3/8â€
