Hi Guys
Those that have done this what diameter wire and what radius
are the hoops on the side of the turret to hold camo.
I know there are normaly 5 per side of the turret.
Any ideas
Turret hoops for camo on Panther
- Has liked: 219 times
- Been liked: 200 times
- Been liked: 15 times
Hello Derek
Hope you are well. Ive used 2mm wire and a 3mm radius.4 on the side and 1 around the corner at the same hieght as the bottom hoops.They were used for folage and as far as i know fitted for the normandy hedge rows.
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Hi, got my wire ordered. Below is a photo (found on the web) of the camo hooks with wire or string in to help with holding the foliage. Is this correct
as it looks quite neat and finishes it off
Thanks Antony
Thanks Antony
Hi Kent,
If the hoops were factory applied then they would have to be removed to fit the spare track hangars seen on quite a few late Panther G's.
Have you any original photo's of the wire between the hoops or is this just fictional
Can't see any wire on the photo below even though there is foliage attached to the turret.
Thanks Antony
Thanks Antony
- Been liked: 177 times
Antony,
I was glad to see you got your idlers working OK.
From what I've read and seen(I'm no expert disclaimer), the hoops were a very late war addition and were done at the factory. By then, they were putting foliage on them before they left the factory! Allied air supremacy and all.
I like the looks of the cable/rope through the hoops. My feeling is that the photos we see theses days represent a small sampling of what was on the battlefield 63 years ago. Who's to say there were no field mods done earlier. I would guess they did anything they could to turn their tanks into rolling bushes that go boom.
I plan on having track links on my turret plus foliage.
Boy that Panther in your photo has a familiar camo job
