Sooner or later I'll get this tank built and I'll quit bugging you guys!
I'm using my IX20 to run the Sherman. I set it up to have elevons with channel 2,3 running the drive motors. When I move the right stick fully forward both tracks move forward very slowly. If I move the stick fully forward, right the left track moves much quicker, likewise if I move right. The drive motor operation seems fine but why can I not get full speed out of both motors when the stick is fully forward (centered left right). Why do the motors run much quicker on full right or left.
My dual rates are 100% and I have not modified the travel adjustment either. Gotta be something I'm missing in the radio setup I'm guessing.
Thanks, Jerry.
Single Stick Spektrum Programming Issue
- Been liked: 2 times
- Has liked: 1341 times
- Been liked: 1538 times
Re: Single Stick Spektrum Programming Issue
You need to up the end point adjustment to get full speed. I set them to 150%, which might be over kill but means you get the best forward speed. You could probably tune it back so that stick fully forward just gives 100%. I think I get about 109%. Who knows, maybe the speed controllers go up to 11 ?
Use the Monitor screen to see how things are affected by changes.
Hey Adrian, thanks for the quick reply. Running my travel to 150% didn't seem to correct the problem. Using Elevon for wing type is what I want isn't it? As you mentioned when using the monitor and the stick fully forward but centered the travel will show 110. If I take the stick to the corners it shows the travel at 150. So, the transmitter must not be allowing me to reach the full 150% travel in full forward or reverse.
Yes, I have this DX8 set to Wing: Elevon Tail: Normal.
RAL and LAL are set to 150% travel.
Stick fully forward is full speed ahead (112%). Moving it into either corner doesn't increase the speed of the tracks.
- Been liked: 35 times
Im running a DX6 and after having multiple issues with proper running I opened the speed controller box and adjusted the swithces so I didnt have to adjust through the computer, works great now.
So you opened the motor control module? Please provide more detail. Jerryjohnny johnson wrote: ↑Tue Nov 29, 2022 11:26 pmIm running a DX6 and after having multiple issues with proper running I opened the speed controller box and adjusted the swithces so I didnt have to adjust through the computer, works great now.
