speakers on the Easy 8
Posted: Thu Oct 27, 2022 5:32 am
by John Burden
I have been playing around with the 2 speakers from the Audio Option pack for the E8. Not found the perfect location, yet I am leaning towards facing up below the engine grills.
What have others done?
Re: speakers on the Easy 8
Posted: Thu Oct 27, 2022 2:52 pm
by Andy Walker
I've put mine under the engine grill but one each side of smoke unit facing inwards.
Posted: Thu Oct 27, 2022 3:08 pm
by Erik Dries
this is what i have done
Posted: Thu Oct 27, 2022 9:14 pm
by John Burden
Eric that's a pretty fancy setup you've done. Very nice
Posted: Sun Oct 30, 2022 8:29 am
by Antony Selwood
Very neat installation Eric, what type of board are those components mounted on? and how is it secured to the tank sides?
Posted: Sun Oct 30, 2022 5:00 pm
by Erik Dries
Hi,
It is a 3d printed tray, The the speakers are mounted in a completely printed speakerbox, this is mounted over the smoker. The main tray exist of four levels, three below the one you can see, all the electronics are placed there. the front piece around the battery is just for the looks and to guide some wires to the front. For now it is secured by gravity and the bolt heads from the sponsoon mounting. It can not move from side to side because of the fit.
I made a small miscaculation with the space for the turret motor and had to remove material manually, as the print was about 7 days i did not wanto do it again. The print material is ABS.
Posted: Sun Oct 30, 2022 10:59 pm
by John Clarke
Brilliant. That's next level internal lay out
Posted: Sun Oct 30, 2022 11:36 pm
by GlenStenhouse
No room for the smoke pack?
