Hi Guys
For the fighting compartment of a stug III I need to know the plate thickness
around the fighting compartment.at this stage I am interested in the thickness of the side walls and the rear plate , front plates and roof.
As I would like to make these to go on my PZ III
does any one know ?
Online
- Has liked: 218 times
- Been liked: 179 times
- Has liked: 116 times
- Been liked: 1104 times
Hi Derek,
If your building the late one as we discussed 30mm sides and rear, 50mm front excluding any add on armour and between 10mm and 16mm roof depending on which piece,
Dave
Dave
www.armorpax.net
- Has liked: 1369 times
- Been liked: 1567 times
Online
Hi Dave
That's great info thanks just what I needed.
Did you get my email the other day? I used you other address not the armorpax one.
I am thinking of the late one.so running gear should be the same
I would like the fighting compartments interchangeable.
The only other thing that is different is the front inspection hatches.
Hi Derek,
Yes got it, but been a little pre-occupied
Will get back to you in the next day or so,
Dave
Dave
www.armorpax.net
Online
