Radio choices
- Has liked: 5 times
- Been liked: 12 times
Radio choices
Hi folks, Can someone suggest the proven compatible radios to use with the Armortex motion system?
- Has liked: 17 times
- Been liked: 26 times
Re: Radio choices
I use the FlySky Paladin 18. Works perfectly. Track mixing was easy enough to setup. I chose this as there are load more features I use for other RC models as well.
I did have an EV18 but this is a little more fragile on the gimbals and much more than we require.
The price of additional receivers for all my models was also a consideration.
- Has liked: 1467 times
- Been liked: 1642 times
Re: Radio choices
I've used Frsky Taranis X9D, X Lite Pro, Spektrum DX8G2 and Paladin 18EV recently.
Frsky does it for me due to the OpenTX programming capabilities and the telemetry, both Frsky's own and home built.
- Paul Sparkes
- Has liked: 91 times
- Been liked: 233 times
Re: Radio choices
Radiomaster tx16 here, similar to frsky and can use frsky receivers, worth a look.
222 scout car
222 scout car
Re: Radio choices
Only if they are ACCST V1. FrSky 'accidently' broke compatibility with ACCST V2
- William Gardeniers
- Has liked: 46 times
- Been liked: 282 times
