Lead acid AGM charging help needed.
Matt Fidler
Has liked: 21 times
Been liked: 27 times
Post by Matt Fidler »
Hi,
I am taking my tank to its first display tomorrow and want to know if I can charge the battery tonight or is it best to get up early and do it in the morning? Not sure how they hold their charge overnight.
Has liked: 1491 times
Been liked: 1699 times
Re: Lead acid AGM charging help needed.
As long as the tank is switched off they should hold their charge for weeks.
I normally charge the night before.
Matt Fidler
Has liked: 21 times
Thanks Adrian
Gerhard Michel
Has liked: 3 times
Been liked: 690 times
Post by Gerhard Michel »
I think a more interesting question may be which charging system is used. An automatic AGM charger will stop charging when the battery is fully charged; no problem for overnight charging. A simple constant current charger has to be removed when the battery is fully charged to avoid overcharging and damaging the battery.
A fully charged AGM battery may be stored for more than 6 months without recharging. In the first month it can be used without a significant lack of charge. Each AGM battery should only be discharged to 50 % of its capacity (50 % DoD) to avoid untimely wear.
Gerhard
mark j. radick
Has liked: 394 times
Been liked: 538 times
Post by mark j. radick »
If the battery is lead-acid. It is best slow charged
Matt Fidler
Has liked: 21 times
Gerhard Michel
Has liked: 3 times
Well, this charger is an automatic type, which stops charging when the battery is fully charged. There is no reason for NOT charging overnight.
Gerhard
