Is anyone able to help in providing me with the inner and outer dimensions of the 2021 Tiger ring gear, part number CE2409 pictured.
Thank you
2021 Tiger Ring Gear
- Been liked: 22 times
- Has liked: 260 times
- Been liked: 190 times
Re: 2021 Tiger Ring Gear
Are you going to Tankfest? If so bring a tape measure to measure my Tiger. If not then I will try and get it done for you, a rather public commitment!
- Has liked: 428 times
Hi
i checked mine today and have 31.6cm ID and 33.6cm OD
thats what i make it
Donald
Donald
My Tiger has an OD of 336 mm and an ID of 301 mm. However mine is an Early Tiger 2003 Vintage. The critical size I gues is the OD, toothed side>
Thanks for checking but its specifically the 2021 Tiger ring gear that I need the measurement for as its a different size to the early versions.Steve Stuart wrote: ↑Mon Jun 27, 2022 9:11 pmMy Tiger has an OD of 336 mm and an ID of 301 mm. However mine is an Early Tiger 2003 Vintage. The critical size I gues is the OD, toothed side>
OK, Redid the photos of the 2021 Ring Gear,and included the width of the gear this time
i don't normally use that long rule to measure so started to doubt myself and deleted the last set of pictures
