Quad battery
Graham P Hough
Has liked: 26 times
Been liked: 193 times
Quad battery
Post by Graham P Hough »
Advice please : what batteries are folk using for their Quad. I have seen the 'big' lead/acid type but do you use any other type like Lithium?
All help appreciated.
Steve Stuart
Has liked: 263 times
Been liked: 192 times
Re: Quad battery
Post by Steve Stuart »
I have two LiFePo batteries, the same dimensions as the standard Gel Lead Acid but alot lighter, fitted in forward in the rear compartment. I will need to take photos.
Graham P Hough
Has liked: 26 times
Re: Quad battery
Thank you Steve, I only need the reference/code number for them.
Steve Stuart
Re: Quad battery
This is a link to the batteries I used:
https://batterygroup.co.uk/batteries-by ... fepo4?c=76
Q Battery Untitled-4RmMa3SeR3ogEF_200x200@2x.jpg (11.17 KiB) Viewed 4255 times
They are the same size as the standard lead acid batteries used before so out with the old and in with the new! The only thing is that the price has now crept up in the meanwhile...
Graham P Hough
Has liked: 26 times
Re: Quad battery
Thank you Steve.
