Speaker mounting
Derek Attree
Has liked: 219 times
Been liked: 199 times
Speaker mounting
Post by Derek Attree »
Hi Guys
Finally got round to starting the Universal Carrier kit.
At the moment just cleaning panels and priming the steel ready.
I was wondering though what solution people have come up with for mounting the speaker
as there is no mention of it in the instructions and no obvious mounting hardware that I have found yet?
Steve Norris
Has liked: 8 times
Been liked: 701 times
Re: Speaker mounting
Post by Steve Norris »
Hi Derek
I have just used a simple L shaped bracket and mounted the speaker under the grill in the engine cover
Graham P Hough
Has liked: 26 times
Been liked: 193 times
Post by Graham P Hough »
I have bolted underneath the motor cover grille.
Derek Attree
Hi guys
Thanks for the speedy reply I will make a mount
I was just really wondering if I was missing a mount in the option pack.
Obviously not :oops:
Regards Derek
Medard Winants
Has liked: 3 times
Been liked: 2 times
Post by Medard Winants »
I’m working on lasercut subwoofer witch fits in the engine compartment.
Mark Heaps
Has liked: 270 times
Been liked: 327 times
Post by Mark Heaps »
My father also had problems finding where to mount the loudspeaker on the RR armoured car and not wanting to do something wrong then enquired by Armortek.
The answer he recieved from them, which may also be applicable to the Universal Carrier, was that there was no specific mounting point or bracket. Just use the magnet on the speaker to stick it against a steel panel of his choice. Wherever it fitted in best with his wiring layout and gave for him the best acoustics.
Gerhard Michel
Has liked: 3 times
Been liked: 678 times
Post by Gerhard Michel »
Each speaker needs some case around it to avoid a so called acoustic short cut. Without a case the lower frequencies are damped down.
Gerhard
Derek Attree
Hi Guys
In the end I 3d printed a mount before I retireed and hung the speaker under the grill at the rear fo the centre housing . No pictures I am afraid but my running gear set up is completely different to the original design.
I have 2 motors and a 12 volt battery under the centre housing and cut an access panel in the main floor to install the 12v battery. I made my own cover plate from 3mm anodized aluminium plate I had in stock at the time.
Hope this helps
