Wanted 2007 Tiger 1 Elevation Motor Mount (CE0762) now closed.
Chang
Has liked: 16375 times
Been liked: 481 times
Post by Chang »
Hi all Tiger 1 builders,
Have asked and replied by Monique, this part is no longer in Armortek's stock. So I need try my luck from here.
Maybe some one still have it in your spare parts bin, and that is what I am looking for :
2007 Tiger 1's Elevation Motor Mount. Monique said newer Tiger 1 replaced it by the new part (CL0705), but can't be installed without modification.
1-6 Tiger1-320(2).jpg (57.4 KiB) Viewed 2076 times
Thanks in advance,
Lerh Chang
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Re: Want 2007 Tiger 1 Elevation Motor Mount (CE0762)
Post by Steen Vøler »
I will look in my sparepart bin and get back later today
cheers
Steen
Steve Stuart
Has liked: 260 times
Been liked: 190 times
Post by Steve Stuart »
I too will have a look. Steve
Chang
Post by Chang »
Steen Vøler wrote:
Fri Mar 11, 2022 7:26 am
Steve Stuart wrote:
Fri Mar 11, 2022 9:46 pm
Hi Steen and Steve, Am I a lucky guy ? :mrgreen:
Steen Vøler
Has liked: 62 times
Sorry Chang, I have looked twice and there is none in the sparepart bin
Hope you find a solution
cheers
Steen
Martin Usher
Has liked: 25 times
Been liked: 62 times
Post by Martin Usher »
Chang you have a PM
Martin.
Martin Usher
Has liked: 25 times
hope the pic comes up, not having a lot of luck here.
Chang
Post by Chang »
Hi Martin,
Thank you for showing me this picture. PM replied.
Lerh Chang
Chang
Post by Chang »
Hi all, Still open for any offer from any Tiger 1 builder. Thanks.
Christoffer Ahlfors
Has liked: 745 times
Been liked: 359 times
Post by Christoffer Ahlfors »
I suggest you take my CAD file for this bracket instead and roll your own and better version:
Additional material required are two ball bearings, two sprockets, a piece of chain and a small shaft to fit the bearings and leadscrew.
Alternatively, you can copy Martin's design here: viewtopic.php?f=6&t=6073&p=51649#p51649 (scroll down to June 21st!)
If you really, really, really want the original bracket, I am pretty sure I have one here, but it will be expensive with all the charges incurred by its travel...
Chang
Post by Chang »
Christoffer Ahlfors wrote:
Wed Mar 16, 2022 2:59 pm
... If you really, really, really want the original bracket, I am pretty sure I have one here, but it will be expensive with all the charges incurred by its travel...
Hi Christoffer,
Thank you for your advices. From your photo and Martin's design threads, I can see the nice updating details. Only the CAD is beyond my level :oops: .
Yes I do really, really, really want the original bracket (CE0762) from you or any owner. I know that it won't be cheap with reason, but am willing to pay for it. Please advise me further ( in PM if you rather to).
Lerh Chang
Chang
Re: Wanted 2007 Tiger 1 Elevation Motor Mount (CE0762)
Post by Chang »
Hi all AT owners,
Steve Stuart
I have finally found it. But do you still need it?
Chang
Post by Chang »
Steve Stuart wrote:
Fri Mar 25, 2022 5:26 pm
Hi Steve, Thanks again for the reply.
If it is exactly the CE0762 as shown in the 1st floor (ie, 4 holes), then YES I want it. :D
If it is the older type (ie, 3 holes), then NO as I have already received one. :-| But still thank you for looking for me.
With regards,
Lerh Chang
Steve Stuart
PM Sent Steve
