Hi all.
I'm about to make some lifting lugs for the exhaust armour shields. Does anyone know the correct dimensions?
TIA
Exhaust armour lifting lug
- Has liked: 380 times
- Been liked: 261 times
Re: Exhaust armour lifting lug
Just a follow-up on what I did regarding the lift lugs.
Turned the lugs in brass on a lathe.
Dimensions i used was:
The shaft: 5x12mm
The endknob: diam 8mm 2.5mm thick.
I drilled a 5mm, 11mm deep hole and adjusted the lenght of the complete lug to protrude 7.5mm from the casting. I glued mine in with slowcuring CA.
Correct placement and depth of the lug should be determined by your heatshild cutouts.
The shaft: 5x12mm
- Has liked: 63 times
- Been liked: 4 times
Yesterday I started looking for information about the lifting lug
Thanks for the post
Roberto
Thanks for the post
Roberto
