Speaker Wires.
- Been liked: 18 times
Speaker Wires.
Question, I'm installing two Satellite Bose Speakers. They require a negative and positive hook up. The connection wires from Armortek are color coded White and Blue. Does anyone know which wire is negative and which one is positive? Many thanks....Tom
- Has liked: 380 times
- Been liked: 261 times
- Has liked: 1467 times
- Been liked: 1642 times
Re: Speaker Wires.
The actual polarity doesn't matter but you need to take into consideration how the speakers are positioned.
If they're pointing the same way, then connect them the same.
If they're pointing towards or away from each other then they need to be wired opposite to each other.
You'll tell from the sound quality and whether you get dead spots when you move your head as to whether you have it right.
