2021 Tiger question.
Søren Sandvold
Has liked: 380 times
Been liked: 261 times
Post by Søren Sandvold »
Hi.
I have just received my 2021 late Tiger 1 kit. :D
Now, I have been looking over the kit and it's content, and as i have read a lot if older building blogs I notice that there are several new upgrades/changes to the kit. There is one thing new that raises a eyebrow. There is no longer O rings on the suspension arms/shafts. (The O ring between the shaft and bronze /brass bushing) And no oilring on the sprockets driveshaft.
The omitted oil seal on the drive shaft I can somehow understand, but the leaving out the O rings seams odd :?:
Any thought on the matter? Should I take the time and effort to machine a groove and install the O rings?
When the time comes to actually start this build, i will do a build blog, unless you're all tired of seeing Tiger builds :lol:
Been liked: 3680 times
Re: 2021 Tiger question.
We agree Søren - look forwards to seeing your build photos on the forum. Everyone does things a bit differently, so it will be fun to see how you do yours.
The 2021 Tiger 1 does feature quite a few changes/ improvements compared with previous kits. With regards to the O rings - we removed these from our kits a few years back as they did not prove to be very effective.
Been liked: 1824 times
Every build is different in some way, new idea's, techniques, help, guiding, impressing and inspiring.
Without input the forum's high quality output would wither.
Even if it's just a steady build I'll read and watch it grow.
Every picture is worth a thousand words (unless it out of focus, then it gets just one or two :roll: )
So bring it on and enjoy. 8)
Søren Sandvold
@ Armortek : thanks for the clarification on the o rings. It seams like a good ide on paper, but trust you on that they are not necessary.
A build blog will follow :D
