Sherman return rollers / wheels and M3x16mm short for dual roller
- Has liked: 17 times
- Been liked: 26 times
I've found that the M3x16mm are fine for the single wheel roller but there's barely any thread coming through on the dual wheel roller as the flange is a lot thicker. Not even enough to get through a nut on the other side. What has everyone else fitted here? The M3x16mm with about half a turn engagement or did you go to M3x20mm?
- Has liked: 134 times
- Been liked: 137 times
Re: Sherman return rollers / wheels and M3x16mm short for dual roller
I've not quite got to that point yet but found some of the other bolts are a bit short.....barely reaching the other side of the nut, so have just gone to the next length available. Its meant buying extra bolts but always useful to have extra bolts / nuts of varying sizes.
- Tom Miller
- Been liked: 347 times
I used the 16mm and they worked OK.
Tom
Tom
Thanks for the reply. I can only get them about halfway through the nut. There's no paint thickness there either.
Thanks for the reply. I figure going to M2x20mm. I've found the front hull is varying thickness but this is to be expected front he casting process. It says to pack the screws with washers if they're too long but the lower ones don't make it through the casting at all. Easy fixes, just wanted to be sure I wasn't missing a trick or had an earlier print assembly page.Andy Walker wrote: ↑Mon Aug 30, 2021 6:29 pmI've not quite got to that point yet but found some of the other bolts are a bit short.....barely reaching the other side of the nut, so have just gone to the next length available. Its meant buying extra bolts but always useful to have extra bolts / nuts of varying sizes.
