Muttleys SD KFZ 251/8 No1
Forum for discussion relating to the Sdkfz 251
Steve Lewington
Has liked: 8831 times
Been liked: 319 times
Post by Steve Lewington »
Hi everyone
At long last I have finally found the time to start my 251 build.
Before I start I have to thank my dear friend and unsung hero of our forum Stephen white for help and advice on some gaps in my research.
Also my dear friend Phil woollard for all his time and help in teaching me the pain of the TX and RX :roll:.
And lastly Lee archer of Panzerwrecks for his help in sending me some unpublished photos of the interior of the 251/8 free of charge a true gentleman.
All working as it should thanks to Phil not sure if the tx was a bad learner or I was a rubbish teacher lol
Drive gear
Drive gear
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
Has liked: 2279 times
Been liked: 7191 times
Re: Muttleys SD KFZ 251/8 No1
Looking good mate, I shall be watching and making notes as I have one to build very soon 8)
Tim Page
Has liked: 40 times
Been liked: 471 times
Post by Tim Page »
Nice to see another 251 build.
The 251/8 is a good choice for a riveted ausf.C
florian rudolf
Has liked: 297 times
Been liked: 645 times
Post by florian rudolf »
Nice to see. Looking forwart the building blog.
Think abut my 251/9 :D
Steve Lewington
Hi Tim ,Florian.
Thank you for the lovely comments.
Tim I had planed this build 251/8 some 6 years ago sadly health issues had me put it on the back burner along with some of my other models.
Florian I followed your 251/9 with great interest and will certainly use it for reference as I go along.
Take care and stay safe
Best Regards
No respite.
No forgiveness.
Tim Page
Has liked: 40 times
Post by Tim Page »
Hi Steve, do you have anything special in mind for this build?
TBH, I have been wanting a 251 for ages and unfortunately never found an Armortek 251kit for sale when i had the money or the space.
I have just picked up a 251/1 ausf.C (Not Armortek) for £500 last weekend. It is a runner with sound and smoke etc but needs work to tidy it up and then add some detail.
I appreciate it for what it is and it obviously cannot compare to the Armortek quality that i am used to but it was cheap and should look pretty good and from what ive heard they do run quite well.
All i can say is that i will appreciate working on an Armortek even more now.
I guess my 251 itch is now getting scratched.
Good luck with your build.
Steve Lewington
Hi Tim
It was always going to be the 251/8 ambulance.
Reference material of the inside is very sparse I do have a conversion kit for the Tamiya 251/1 to make it into an /8.
Like you its been an itch mine for a long time I'm lucky enough to be able scratch it I do hope your lucky enough to get an Armortek one as its a fantastic kit to work on.
Never got into the workshop yesterday or today children and fencing got in the way but tomorrow is a new day.
Stay safe best regards
No respite.
No forgiveness.
Steve Lewington
A nice day in the workshop today I got quite a bit done.
Thank goodness for the Arber press I had to use it to press in the sprocket pins and to push the sprocket rings on both mega tight.
CNC lines removed from all the road wheels
CNC lines removed
CNC lines removed
CNC lines on the hubs
Undercoat started
Undercoat started
No respite.
No forgiveness.
Steve Lewington
Bit more done today in the workshop.
This is one of those kits that benefits from painting as you go and touch up afterwards.
Take care all and stay safe.
First set of roadwheels top coated
Drive sprockets top coated
Home made spray booth cheep cheerful and works a treat.
Extraction from the booth/box
Road wheels
Road wheels
Steering gear undercoated along with my trusted air gun over 20 years old and still works badly lol
Drive sprockets
Drive sprockets
No respite.
No forgiveness.
Nice me ol mate! 8)
Steve Lewington
Thank you Phil
I will give you a call some time when I get five.
No respite.
No forgiveness.
Steve Lewington
Good evening guys
Managed to get a bit more done in the workshop today.
This is coming together nicely not much in the way of problems that could not be easily fixed.
Take care and keep safe
Frame painted
Frame painted
Steering servo fitted
Inner road wheels made up
Once the countersunk screw was fitted it locked up the road wheel this was simple fixed by adding an M4 washer to open up the space on top of the bush simples.
Outer road wheels coming together
No respite.
No forgiveness.
Steve Lewington
Progress so far.
After fitting all the running gear and ready to set the suspension angle I realised I had made a school boy error DOH.
I should have set the angle before fitted the running gear so the wheels off one side and the angle set.
The set angle should be 15 degrees i have set it at 16 to allow for bedding in.
They say every day is a school day today was a bad one,
Take care and stay safe all.
Wheels on wheels off
16 degrees on the arm.
Zero degrees on the level.
No respite.
No forgiveness.
Steve Lewington
Not a great deal done this past week had some family time with my wee lads Shorty and Tiny doing boy things.
I fitted the front tyres thank goodness once again for the arbour press made pressing the tyres on a piece of cake.
Tracks made and fitted then a dry run on blocks.
One of the tracks kept running off its sprocket and stopping in both directions :cry:
After a check over there was an alinement problem so in true Armortek fashion tracks on tracks off to coin the phrase then strip it all apart again and start from the beginning.
It could have been a lot worse it could have been both sides.
No respite.
No forgiveness.
Steve Lewington
Good evening gents
Well not a great deal done over the past few weeks unfortunately i had to don my old builders hard hat so the 251 had to take second place.
Starting to get a bit of time now so this week I have been dry fitting parts to see how best to proceed with any upgrading.
Here are a few photos of what I have done so far.
Keep well everyone and stay safe.
The bonnet is quite long 20" in length
One day I'm going to get this figure a pair of boots.
The rear doors quite a bit to be done on these to get them looking anything like the real thing.
The cab again lots to do on it,
No respite.
No forgiveness.
