'2019' King Tiger - Stopped Running.
Tom Wittstock
Been liked: 18 times
Post by Tom Wittstock »
All, maybe this has happened to you. Installed the Motors along with the electronics from the motion pack. All went well. Tank stated up and ran good. Next day went to startup the tank and got nothing no sound while the on/off switch was turned on. The Armortek Power Module display shows the normal voltage numbers and the batteries and all show that they have a good charged. Maybe someone could give me a check list on what to trouble shoot...
Many thanks. :D
Christoffer Ahlfors
Has liked: 749 times
Been liked: 360 times
Re: '2019' King Tiger - Stopped Running.
Post by Christoffer Ahlfors »
1 fuses
2 RC connections
Mark Heaps
Has liked: 270 times
Been liked: 327 times
Post by Mark Heaps »
Maybe a stupid question but did you switch the tank on before the transmitter ?
On - Tx first then model
Off - Model first then Tx
Also I have read that it is best to have the Tx at a short distance from the model >2m so that they bind correctly.
Has liked: 1495 times
Been liked: 1699 times
There's only one fuse in the new Red Box system, so that's a quick check.
What receiver do you have ? They usually have an LED in them to show the RX is alive and bound to the transmitter. FrSky are solid green if happy and flashing red if it can't talk to the transmitter. I believe the Spektrum show a solid amber light when communicating to the transmitter and nothing if it can't talk to it.
Do you get a thump or a squeak from the speakers when you turn on ? Thump means the amp is getting power, squeak means the sound card is getting power, which means that the receiver is getting power, as it powers the sound card.
Tom Wittstock
I'll check from all advice. Nothing else has been installed just the motors. The radio is an older radio called AIRTRONICS VG6000.
Thanks to everybody
Tom Wittstock
Tank started up ok. Running great. Don't no the reason or reasons why it stopped and now running ok... :D
