Difficulties with motion pack A
Jerry Carducci
Has liked: 3 times
Been liked: 1116 times
Post by Jerry Carducci »
I'm carrying this over from the discussion on OpenTx systems as it no longer is relevant to that topic.
To recap: I'd begun bench testing my electricals using the Taranis X9D with X8R receiver. I'd had issues with one
main drive motor having no neutral. I next tested the system using a old Spektrum DX6 with 610 receiver. Same
result.
So lastly I removed all other modules and simply tested motion pack A and the power module. Same result- one motor
refuses to stop at neutral. There are no mixes defined on this radio it's purely plugging the modules in and trying basic function.
Batteries are all fully charged, connections appear sound and the received is new- never had been bound before.
I'm not usually one to wave my hand for help ( doesn't come easy!) but not wanting to swim against the stream this time I'm
open to suggestions. I made a brief video of this last test so that what was done may be readily seen...
Motion pack A test
Mark Heaps
Has liked: 270 times
Been liked: 327 times
Re: Difficulties with motion pack A
Post by Mark Heaps »
Looks to me like you have to set up the fail-safes.
Jerry Carducci
Has liked: 3 times
Mark Heaps wrote:
Tue Mar 23, 2021 7:49 pm
When the Spektrum receiver was bound to the transmitter the sticks were all set to center. When I was using the Taranis and X8R
I explicitly defined all the fail safe positions for all channels as 0. I hope that would cover both scenarios.
Also in the video above (as in all my tests) the transmitter was powered up first. I know there can be a momentary delay before the receiver
recognizes the transmitter signal when controls might twitch but they should quickly assume their proper position. In view of
the sequence in the testing I don't believe the fail safe positions come into play; at least not very long.
Tim Page
Has liked: 40 times
Been liked: 471 times
Post by Tim Page »
I had a similar problem last year trying to setup 2 Viper speed controllers with a pair of 540 motors.
For some reason i could not get them to both sit at neutral.
They were the Auto setup type and both worked perfectly on their own but refused to work correctly as a pair.
I gave up in the end after spending several evenings pulling my hair out.
Back to the drawing board when i revisit that project.
Good luck.
michael hilton
Has liked: 1566 times
Been liked: 836 times
Post by michael hilton »
Hello Jerry, are you plugged into Elevator and Aileron on your receiver....for left and right motor. ...Mick
Jerry Carducci
Has liked: 3 times
michael hilton wrote:
Wed Mar 24, 2021 11:27 am
Yes for the purposes of that test, yes I ws indeed plugged into Aileron and Elevator, intentionally as I wanted
both controls on a self-centering stick ( recall Mode 2 xmitter). The result was the same using left stick rudder
and right stick aileron - the same motor refused to stop without trim adjustment while the other responded normally.
I even went so far as removing one of the two inputs' positive lead temporarily (from the 'Y') to ensure I wasn't experiencing some
odd feedback - same result - one motor behaved normally and the truant motor just motored on when I said stop...
So I've expended all the tests my weak brain will come up with...
Mark Heaps
How long have you had the motion packs ?
I seem to recall reading on the forum that early ones provided the receiver from muliple sources with 5 Volts ( both motion pack A & motion pack B ) which then caused problems.
Does the problem still exist if you disconnect all other connections to the receiver apart from those needed for the two drive motors ?
Ray Brown
Has liked: 26 times
Been liked: 103 times
Post by Ray Brown »
G'day Jerry,
may i suggest that you swap the blue & yellow leads on the motor that drives constantly. i had it happen once ànd fixed it doing that. electronics, go figure.
cheers
Ray
LesBernell
Been liked: 34 times
Post by LesBernell »
Jerry,
Have you tried swapping the plugs for the Main Drive Motor 1 and Main Drive Motor 2?
It probably won't correct the problem, but if the problem persists on a different motor; you will know it's not an issue with a motor.
If the problem persists with the same motor; it's a motor problem.
Les
Jerry Carducci
Has liked: 3 times
With Kian's guidance the difficulty with motion pack A seems to have been successfully overcome!
Many thanks to Kian.
Ray Brown
Has liked: 26 times
Post by Ray Brown »
Jerry Carducci wrote:
Thu Mar 25, 2021 7:31 pm
G'day Jerry,
what was the remedy?
cheers
.Ray
Jerry Carducci
Has liked: 3 times
Ray Brown wrote:
Fri Mar 26, 2021 12:05 am
G'day Jerry,
cheers
.Ray
Hello Ray. Not quite certain how or if I can reply to this: sharing the details as it will invalidate one's warranty.
Then there's this:
"It is a blessing for a man to have a hand in determining his own fate."
-Edward Teach
