Hi All,
The assembly manual for the Tiger 1 (and I assume for other models) suggests chamfering the teeth on the sprocket rings. I have a mini-lathe and was wondering if that would be a good thing to use. I am concerned about 'shock' loading the tool as each tooth passes the cutting face. I would appreciate some guidance. Many thanks,
Alastair
Sprocket Teeth
- AlastairCooke
- Has liked: 16 times
- Been liked: 758 times
- Has liked: 219 times
- Been liked: 198 times
Re: Sprocket Teeth
Hi Alastair
Thats exactly what I did on my Ferdinand build light taking cuts.
8 sprocket rings done in about an hour inside and outside faces.
- AlastairCooke
Re: Sprocket Teeth
Thanks Derek. Good to know it is a feasible approach.
Alastair
Alastair
Alastair
- Has liked: 785 times
Re: Sprocket Teeth
Hi Alastair
I used a 3 jaw chuck it worked fine held them like Vince well supported.
