Page 1 of 4
Florian StuG build
Posted: Fri Feb 26, 2021 8:24 pm
by florian rudolf
Now I'll start my new building block of my secound StuG from Armotek.
First building pictures comming soon
Re: Florian StuG build
Posted: Fri Feb 26, 2021 10:04 pm
by florian rudolf
StuG meets Famo
Start building
Posted: Sat Feb 27, 2021 8:12 pm
by florian rudolf
Today it is going on at hull, gear, and wheels...
Had some trubble with my driven gear, like I read it allready, so I had something to drill.
Posted: Sat Feb 27, 2021 8:14 pm
by florian rudolf
It looks realy smal next to the Famo
But fortunatly there are many parts comming soon to make the StuG bigger.
Posted: Sun Feb 28, 2021 8:19 am
by Roy Beukeveld
Hi Florian, good luck on your new StuG build!
I’m looking forward to seeing your progress and accomplishments.
Btw, the size comparison with the Famo is impressive
Posted: Sun Feb 28, 2021 7:09 pm
by florian rudolf
Thank you Roy,
well I don't want to bore you guys, because here are many threads about the StuG. I'll post all I make diffrent way to the kit.
Now I still working at the normal hull stuff. the welging is comming soon.
Some hull parts I plan to take in my sand blast cabine.
Florian
Posted: Sun Mar 07, 2021 7:58 pm
by florian rudolf
Did some work this weekend...
1. I had to drill down the inner roadwheels, because the chain teeth are a little too thick...
Posted: Sun Mar 07, 2021 8:02 pm
by florian rudolf
2. I blasted different parts. This is used for the later look
Posted: Sun Mar 07, 2021 8:07 pm
by florian rudolf
Last but not least I started to make the the suspension.
Finish for today. It lokks like a tank now
Posted: Sat Mar 13, 2021 7:01 am
by florian rudolf
Last time I did some work on the track wheels.
I drilled the sleeves for a bit better looking scale look out.
Big brother is whatching grow up
Posted: Fri Mar 19, 2021 7:01 pm
by florian rudolf
Posted: Sun Mar 21, 2021 8:15 pm
by florian rudolf
Its wellding day halleluja.....
I did nearly all wellding work today. Next thing is the primer paint and begining to do more detailing
Posted: Mon Mar 22, 2021 6:03 am
by Steen Vøler
Well done
Posted: Sun Mar 28, 2021 8:51 pm
by florian rudolf
Hi all,
today I did something an the upper hull top roof.
I'll fix it with neo dyn magnets (5mm x 2mm). I pressed the magnets into the 3mm hull plate, where the metal holders for the cover is. Than I glue ftom the top side with 2k alu metal glue. I need 24 magnets. It fix it perfectly and strong enouth.
Forther I did some model M3 screws for scale look.
Also optimized the wellding on the track wheels.
Florian
Posted: Sun Mar 28, 2021 9:07 pm
by Christoffer Ahlfors
Wow!
That's a lot of magnets!
Interesting concept!
