Main drive system
- Been liked: 5 times
Main drive system
Having had problems getting the main drive to work I had dismantled and rebuilt several times to no avail .Then the light in my brain glowed and I moved the flywheel EP0602 back as far as I could while ensuring the grub screw held it securely .then moved the coller that links the short drive shaft to EP0605 similarly rearwards , now the drive works perfectly and I can prograss to ensuring the motor sound modules all work as they should and then fitting the armor
