Track issues
- Has liked: 5 times
Track issues
Hi all, I'm having issues with the tracks catching on the screws that mount the fuel can brackets on the arches and also the front side skirt screws. I cant see any way of moving the wheel arrangement to enable the tracks top run without catching these screws. Any ideas?
- Been liked: 10 times
Re: Track issues
Hi, I had the same issue but found I could use a small, Dremel mounted cutting disc to remove the excess bolts as close to the nuts as possible. This gave just enough room for silent running!
- Has liked: 26 times
- Been liked: 193 times
Re: Track issues
Thanks Phil/Graham
I did think about that but I thought I may have done something wrong.
