sound effect
vincent hung shu yue
Been liked: 24 times
sound effect
Post by vincent hung shu yue »
Hi everybody,
I am seeking for help, I have connected all the wiring, everything are all right except the sound. I had test the speaker with other ampifier, the speaker is no problem. And I follow the insturction of the sound card,
push the programme button, the led flash 3 times and turn on green light for few seconds and flash. But there is no sound at all even I adjust the button of the volume .
Many thanks
Vincent Hung :( :(
Hi Vincent,
Don't feel bad. I had the exact same experience when I was first setting up my sound. Gill was kind enough to replace it with an upgraded one and this time I did not attempt to push the "program button" as I am too afraid of losing sound again. :oops: I still do not have MG sound but motor start, rev, and shut down sound great.
I look forward to hearing what others have to say in regards to your problem as I have been tempted to try the program button again to get the MG sound to work. Too scary though.
I just wanted you to know you aren't the only one who experienced this. :)
sound effect
Hi Tim,
Thanks for your informations. I had told Gill about the problem and still waiting for reply. I will try to complete the Jagd this year. And in the coming year I can put all my hours for the King Tiger.
Vincent Hung
Been liked: 3712 times
Hi Vincent
It sounds like your amplifier is not working. Check the power connections to the amplifier and the lead from the sound card to the amp. If you have no luck, the only option is to return the sound card and amp to us for repair.
