Yves Stug III update
- Been liked: 741 times
- Steen Vøler
- Has liked: 62 times
- Been liked: 500 times
Re: Yves Stug III update
Still a couple of months until shipping i guess.
I am also preparing myself for one
cheers
Steen
Steen
Hi Steen,
I am going to follow your build with interest ,
there are a couple of interesting build logs of the stug III on the forum.
Good for inspiration .
Best regards Yves
Best regards Yves
Hello,
Good news in corona times,
my stug will arrive by the end of the day,
pictures coming soon
Regards Yves
Regards Yves
- Steen Vøler
My StuG 3 will land Wednesday 21.october and a build thread will also be created on the forum.
Cheers Steen
Cheers Steen
cheers
Steen
Steen
- Steen Vøler
You are having a good start Yves
What have you used to secure the brass bushings
I gave some loctite 638, but don't know if that is strong enough
cheers
Steen
Steen
- Been liked: 3704 times
We use 638 - it is strong enough .. and if you ever need to get the parts apart again, you can gently loosen the adhesive with heat from a heat gun or your favourite hair dryer.Steen Vøler wrote: ↑Sat Oct 24, 2020 3:21 pmI gave some loctite 638, but don't know if that is strong enough
Kian
- Steen Vøler
- Roy Beukeveld
- Has liked: 171 times
- Been liked: 118 times
Hi Yves,
Looks like you made a good start there, the weekend is being spent well!
I started mine also but currently doing a dry fit to familiarize myself with the model since it’s my first build.
I see you already started with priming the parts as well, enjoy your build
Kind regards,
Roy
Roy
Hello Steen,
I use Loctite nr 648 for the bushes or cilinders
Loctite nr 243 soft for bolts
Loctite nr 2701 strong for the shafts
Locitie nr 480 to put the rubber rings on the wheels
Hope this helps you
Best regards Yves
Hope this helps you
Best regards Yves
- Steen Vøler
