Colleagues
Eventually got my order from FOA before Christmas, one of the items I got was the blow torch cover, but on there site the screws the kit comes with have a cone head attached, but on my kit I have 2 pan head screws and nuts and 2 brass cone heads not drilled and tapped.
I do not have the kit nor skills to drill and tap these 2 small cone heads so does anyone know where I may get some that are already pre drilled and tapped?
Cheers Allan
Blow Torch Cover
- Has liked: 792 times
Re: Blow Torch Cover
Hi Allan
I had a similar story with my cover but instead of the pan head screws I had two lengths of threaded rod and two nuts. I tried to see if I could find ready-made cone head screws but could not find that small. The cone heads are so small that I decided that I did not want to risk drilling and tapping them. So I carefully drilled a shallow blind hole at the back of the cone heads and glued a piece of metric threaded rod in each hole. I could have also soldered them together but the glue solution seemed simpler at that time.
Obviously, this is not a very strong joint so I was careful when fitting the cover with these screws not to overtighten them.
p.s. If you are eventually still stuck and can't do anything, send them over and I will do it for you.
- Been liked: 10 times
Hi Vince
Thanks for the advice and the very kind offer to do it for me, which I greatly appreciate.
Cheers Allan
Cheers Allan
