PTFE rings for early Tigers
David Pengelly
Been liked: 2 times
Post by David Pengelly »
I have 2 sets of ptfe rings suitable for the early mid production Tiger, where the split brass ring was used under the turret .
No more of these will be made once theses 2 set are gone .
The options are drilled and countersunk or plain .
Please pm me if you require more information.
Was die Hölle das war
Paul Butler
Post by Paul Butler »
Hi David,
I hope I'm on the list who require 1 set of PTFE rings not drilled.
Sent an order in July,please confirm.
Regards Paul butler
Paul
Steve Stuart
Has liked: 263 times
Been liked: 193 times
Post by Steve Stuart »
Hi David
The PTFE Rings that you sorted me out with at the Open Day, really do the business, the turret turns with ease now! Much better than the brass bearing, my next challenge is the blank firer, getting that working smoothly.
