Help in locating page in tiger1.info
Has liked: 792 times
Last March I downloaded a diagram showing the location of the six flat headed bolt on the turret roof.
Looking at this diagram, it's pretty obvious that I must have got it from tiger1.info website. Problem is today I went to look for the page which has this diagram and I just can't find it. Can somebody please direct me to this page which has this diagram?
I am looking for this page as it might tell me the diameter of these bolt heads which is not shown on the diagram. Anybody have this info?
Has liked: 1481 times
Been liked: 1687 times
Re: Help in locating page in tiger1.info
If you know the distance between them from the drawing you have, then you should be able to extrapolate the diameter from the drawings here:
http://tiger1.info/EN/Hachette-Gun-Lock-Bolts.html
Kent Wiik
Has liked: 6 times
Been liked: 194 times
Post by Kent Wiik »
Hi Vince,
22mm, the same as on the Turmfugenschutz.
http://tiger1.info/EN/Turret-ring-protector.html
It´s all in the details!
Thanks for the info Adrian and Kent.
During the last couple of days I have been searching for a good photo of the actual position of these bolt heads. In the above diagram it shows them exactly between the turret weld seam but in the Jentz & Doyle book (page 149) it shows them in a slightly different position closer to the weld seam.
Finally found a good photo of the Vimoutiers Tiger showing exactly this feature.
https://panzerplace.eu/vimoutiers-tiger ... rousel-324
Looks like it is exactly like the diagram above.
Christoffer Ahlfors
Has liked: 746 times
Been liked: 359 times
Post by Christoffer Ahlfors »
Regarding another discussion, the picture before that one shows how tightly the mantlet goes to the turret. You can barely fit a fingernail there!
