Sorry I have been MIA but I am moving my shop into a new area. Can’t wait to work on my models in this fantastic space. Here it is. I will keep posting as the move progresses here and my other build threads across the board.
Looking forward to it.Ok, finally ready to drag my tank into the shop.
Sorry to hear you are still having problems. Did you try checking wheel alignment with a metal tube or rod like Phil did (viewtopic.php?f=6&t=7717&start=30)? If the problem is on one side did you try swapping around the sprockets?Just frustrated worked on it all morning and keep throwing the track off.
Vince Cutajar wrote: ↑Tue Jul 02, 2019 9:22 pmSorry to hear you are still having problems. Did you try checking wheel alignment with a metal tube or rod like Phil did (viewtopic.php?f=6&t=7717&start=30)? If the problem is on one side did you try swapping around the sprockets?Just frustrated worked on it all morning and keep throwing the track off.
Just a thought.
