Proportional Engine Fans
Has liked: 1363 times
Been liked: 1556 times
Just to pick up on what Steve Norris asked in Phil's build thread:
"So are you saying I can link 4 x 24v fans in series with smoke fan and they will run proportionally when the engine sounds are played"
You can link as many fans as you like to my smoke fan control box, though if they are 24V they would need to be in parallel.
By linking the fans to the sound system and not the motors, the fans in the cooling housings would rotate at a speed proportional to the engine speed, even when the tank is stationary - and lets face it, that's the only time they would be visible :lol:
And with Thomas Benedini's current Flash software, you can set the idle speed to a point just above the stalling speed of the fans, so that they can be seen spinning slowly at idle and speeding up when the engine is revved.
Last edited by Adrian Harris on Tue Jun 18, 2019 10:55 am, edited 1 time in total.
Steve Norris
Has liked: 8 times
Been liked: 688 times
Re: Proportional Engine Fans
Post by Steve Norris »
Hi Adrian
That’s just the sort of information I was after.
mark lawson
Has liked: 2490 times
Been liked: 443 times
Post by mark lawson »
Sounds excellent
RAG Militärmodellbau
IG Militärmodellbau
mark lawson
Sounds excellent
IG Militärmodellbau
