As I'm in the process of cleaning and priming I was curious if anyone has had issues with adhesion of the tires to the wheels after the wheels had been painted? I'm wondering if I should tape the adhesion surface off for the priming/painting or is that overkill? I do note that most builds that I've looked at just paint the entire wheel.
Thanks,
Adam
Loctite and painted wheels
- Has liked: 1475 times
- Been liked: 1674 times
Re: Loctite and painted wheels
Not sure about the tyre type but ordinary Loctite melts paint, so I'm planning on taping off that part of the wheels when I get round to them on the Tiger.
- Brian Ostlind
- Has liked: 975 times
- Been liked: 2068 times
Loctite won’t work over paint do mask the contact area. Maybe epoxy if you want to glue to the paint
