Page 1 of 2
PAK 43 2018 arrived in Denmark
Posted: Tue Dec 18, 2018 7:33 am
by Allan Carlsen
Hello and good morning
Just arrived here in Copenhagen yesterday. :D
The next couple of days I will check to see if all the parts are in box. Lots of parts :shock:
Re: PAK 43 2018 arrived in Denmark
Posted: Tue Dec 18, 2018 10:43 am
by florian rudolf
Hello,
its a nice modell you get to build.
Do it with the spirit of Armorpax.
Posted: Tue Dec 18, 2018 11:17 am
by Steen Vøler
Nice Allan
will be good to see it at the battlefield in the spring :-)
Posted: Wed Jan 23, 2019 4:31 pm
by Allan Carlsen
Hello all
Some update on Pak 43.
Posted: Wed Jan 23, 2019 5:04 pm
by Vince Cutajar
Thanks for the update Allan.
Comparing the length of the barrel and the wheels to the kitchen sink gives a good idea of size. Never thought that it would be so big. Keep it up.
Posted: Wed Jan 23, 2019 6:12 pm
by Tom Roslund
Hey Allan , you're going to enjoy the build. I recently completed mine with the Armorpax detail kit. It really helps the look, but definitely changes the challenge level. I'm still a rookie, but am learning fast. I found a turntable to be immensely helpful for building this beast. I built mine using some scrap chunks I milled to fit the chassis without interfering with the gun parts. I've still got the final details to finish, but need a break. :wink:
Tom
Posted: Thu Jan 24, 2019 6:53 am
by Allan Carlsen
Hi Tom
Very fine model. Nice Work. Do you have more Picture. ?
Posted: Thu Jan 24, 2019 10:56 am
by florian rudolf
I've build mine also with Armorpax parts. Looking realy good.
Unfortunatly you can't use all Armorpax details, otherwise the PAK wouln't run anymore. So you have to think about the using of that model.
You may have al look at my building report.
http://www.rag-mm.de/Forum/thread.php?t ... f49d0f0c3b
Posted: Sun Jan 27, 2019 6:38 pm
by Tom Roslund
Yes Allan, I've got a few more. I'm just a bit disorganized, and haven't compiled them yet. I'll get some more posted. The details kit made for a fun and educational build. As Florian mentioned, some pieces will not allow the model to move in some of it's functions. The suspension lockout parts would not allow the gun to be towed and use the suspension, so I left them off. Was an interesting journey figuring out how they worked in reality! Also the traverse got blocked by the size of some resin details for the suspension, but I left them as I didn't feel like modifying as I'm not anticipating traversing the model. I also got a bit intense with hiding the most obvious screw heads that took away from the scale visuals. There was much countersinking and puttying over flat head screws. It does help if one's so inclined to clean up the details. And resin parts are certainly a delicate operation to manage!
Tom
Posted: Mon Feb 04, 2019 6:38 pm
by Tom Roslund
In my goal of hiding screws, and keeping the model disassemble-able, I came up with this idea for the recoil compensator. I probably took it a bit far, but once I got it in my head, the mechanic in me wants to make things serviceable regardless :wink: . I added some small bolts for detail look, and used magnets and dowels to secure the unit to the main structure. I'm learning as I go...
Posted: Fri Feb 08, 2019 8:57 am
by Allan Carlsen
Hello all
Thanks Tom, very nice pictures you got there.
Here is a little update on my Pak 43. On Sunday the wheels will come on.
Posted: Fri Feb 08, 2019 10:51 pm
by Tom Roslund
Wow, seems like a lifetime ago ! Here's my recoil spade mods. I took some artistic license and used Knupfer's threaded studs to show on the face of the spades. Seemed to flow better with all the other riveting, and a believable fastener compared to the kit screws.
Tom
Posted: Thu Feb 14, 2019 7:25 am
by Allan Carlsen
I have come a little further on my Pak 43.
Thanks to Florian & Tom, nice Picture, good details.
Posted: Thu Feb 21, 2019 7:04 am
by Allan Carlsen
Hello all
Some small update on Pak 43.
Thanks to Bryan for making great pictures with many good details. I couldn't get it together without his Pictures. :D
Some of the things teased and had to be separated again. :shock:
Posted: Thu Feb 28, 2019 11:12 am
by Allan Carlsen
Hello all
I made the shield on my Pak 43 here in the last couple of days. Some hard Work. :shock:
