A Warning.
Has liked: 1475 times
Been liked: 1674 times
A Warning.
How do you turn this:
Into this ?
You leave a single LiPo battery charging, inside a "fireproof" bag, in your workshop and nip inside for a quick comfort stop.
I must admit I've taken the stories of self-combusting LiPos with pinch of salt, and always assumed they had been abused, crashed or whatever beforehand.
Not any more...
dennypatterson
Been liked: 1 time
Re: A Warning.
Post by dennypatterson »
:x :oops: Oh dear, expensive..normanly thats my forte, not this time!!! I'll stick to rolling them.who was the poor fellow? Could be good for a few spares.. "But there for the grace of God go I" Denny.
Re: A Warning.
I don't believe he's on the forum.
The plan is to get it going again, if Monique still has enough stock of parts !!
Online
Steve Norris
Has liked: 8 times
Been liked: 701 times
Re: A Warning.
Post by Steve Norris »
Looks like one of Phil Woolard’s range targets.
I hope the owner can rescue it.
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Re: A Warning.
Post by Steen Vøler »
Poor guy - this is the worst nightmare to go through.
Hope the workshop did not burn down also
cheers
Steen
Re: A Warning.
Steve Norris wrote:
Thu Nov 08, 2018 6:00 pm
No, he decided to pass it on. I've been lucky enough (I hope) to see if I can resurrect it. For instance, one of the tracks is nearly complete, with a couple of warped links at one end. The other is still fused to the shelving unit on which it was sitting :cry: :shock:
Steen Vøler wrote:
Thu Nov 08, 2018 6:05 pm
Yup, it was nearly totally gutted. He lost all his RC planes, cars, hand and bench tools, spray gear.
Has liked: 159 times
Been liked: 830 times
Re: A Warning.
Dang that is sobering for sure. Never charge Lipo unattended (although I have done it a lot)!
Poor guy. Lipo's are fickle about charging at the right voltages and with balanced charging per cell - hopefully that was followed. So much for the effectiveness of flame proof bags?
I overcharged a NiMh battery for a RC car and it caught fire. I was able to get it outside before it caused any damage to floor. But it smoked, hissed and bubbled for over an hour. Ruined a brand new $40 battery. :shock: But it was my error that caused it. 2 quick charge cycles in a row caused it to get too hot.
That poor Tiger is a range target now for sure. It could probably be salvaged as a towed vehicle for a FAMO or other diorama. But never back to previous glory. :|
Brian Ostlind
Has liked: 975 times
Been liked: 2068 times
Re: A Warning.
Post by Brian Ostlind »
OUCH! :oops:
Online
Has liked: 790 times
Re: A Warning.
The aviation industry takes battery fires very seriously. In fact there are specific procedures that need to be followed in such cases. Obviously the first step is to extinguish the fire (if there is one) with an extinguisher.
The next step is to cool the battery (or the device) as quickly as possible to avoid re-ignition of the fire. This is done by pouring water or any non-alcoholic liquid on the battery or device. Ideally drop the battery or the device in a container of such liquid.
Christoffer Ahlfors
Has liked: 745 times
Been liked: 359 times
Re: A Warning.
Post by Christoffer Ahlfors »
HOLY COW! :shock:
If you manage to resurrect this one Adrian, you will be upgraded to "wizard of the universe" and "master of the impossible"! :wink:
It would be quite a statement for Armortek quality, too, actually... :D Just imagine models made of, eh, hm ...the p-word! :lol:
andyquirot
Been liked: 33 times
Re: A Warning.
Post by andyquirot »
Sorry to see that happened.
What a great restoration project i would love to get my hands on a sad tiger like that.
Regards Andy Q
sean kerambrun
Has liked: 17 times
Been liked: 7 times
Re: A Warning.
Post by sean kerambrun »
WOW..... I never use Lipos.
Feel sorry for the poor owner... Hope it can be rebuilt
Sean
Gerhard Michel
Has liked: 3 times
Been liked: 678 times
Re: A Warning.
Post by Gerhard Michel »
Why does somebody use a LiPo battery in a tank? :shock: LiPos fit airplane models which need a small, light weight battery with a large capacity and very high discharging currents for some minutes of working. This is not at all the operating range for tank models.
I use LiFePO4-batteries in three of my five tanks and lead silicone batteries in the other two. Opposite to LiPo batteries the LiFePO4 batteries are as save as lead acid batteries when used with a battery management system and a suitable charging device, but they have double the usable capacity of lead acid batteries because they can be discharged up to 100 % (lead acids 50 %) without being damaged. They are fit for quick charge in one hour to 15 minutes, depending on the type of the cells. This means you can charge a 40 Ah super cell up to 160 amps (if you can supply the enormous charging power! :wink: )! My cells may be charged up to 40 amps, which requires a charging power of more than 1,200 watts!
Therefore in my opinion there is absolutely no reason to use LiPos in a 1/6 scale model.
The pic shows my 8 cell LiFePO4 battery for my King Tiger before wiring the balancers.
The balancer cables are mounted (one of two banks)
Charging the battery with 40 amps in the lunch hour
Gerhard
Re: A Warning.
Gerhard Michel wrote:
Thu Nov 08, 2018 11:04 pm
The LiPo wasn't being used in the tank, just charged in the shed which happened to also house the tank.
sean kerambrun
Has liked: 17 times
Been liked: 7 times
Re: A Warning.
Adrian Harris wrote:
Thu Nov 08, 2018 11:12 pm
So Adrian he lost his whole shed too?
Sean
