Move of the turret motor installation to the hull
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
Hi all
On a swedish forum I saw this modification to the turret motor installation, where the owner moved it tio be installed in the hull instead of the deck.
Thought this is such a good idea that I wanted to share his picture. I will be doing this to my own Tiger.
cheers
Steen
dennypatterson
Been liked: 1 time
Re: Move of the turret motor installation to the hull
Post by dennypatterson »
:D :roll: Mornin... how about some more detailed pictures. topfixing? good idea .. look forward to reply.. denny.
Steen Vøler
Has liked: 62 times
I will try to get more pictures - and will also measure on my own Tiger how to install.
My guess is that the fixing of the motor to the vertical plate is done with countersounk screws. I have found alu plates on ebay that are ordered and I will update when I do my "dry-run" :D
cheers
Steen
Has liked: 159 times
Been liked: 830 times
Hi Steen
That is a good modification. That way the top deck can be removed and lay basically flat. I think the hull bracket should be reinforced a bit more than shown in picture as its pretty high mounted (ie prevent gear/motor deflection) but other than that looks great!
Thanks for posting.
Fabian Bekkers
Has liked: 190 times
Been liked: 120 times
Post by Fabian Bekkers »
Smart place for the cupola motor Steen 👍
Huzaren prins Alexander 🫡
Steen Vøler
Has liked: 62 times
@Robert - you may be right. Will see if a L type bracket could support the vertical alu part on the horisontal plate, which will fix it for sure
cheers
Steen
Has liked: 1475 times
Been liked: 1674 times
Could you combine the lateral deck support with the new vertical support plate and get rigidity that way ?
Steve Stuart
Has liked: 263 times
Been liked: 192 times
Post by Steve Stuart »
This is an innovation that could be translated to other Tanks as well, a great idea!
