thank you for your comments. I'm very happy to hear that you like it
A little installation
Florians FAMO build
- Has liked: 280 times
- Been liked: 635 times
- Chang
- Has liked: 14960 times
- Been liked: 372 times
Re: Florians FAMO build
Hi Florian,
Very impressive on PAK43/41 firing at (dust /dawn)! One enemy's tank/bunker must be destroyed.
Also glad to see the Ark crate is still there. Have you checked the interior? Dr. Indiana Jones was there ....
Lerh Chang
Lerh Chang
Hi guys,
since the last event I let the FAMO run, I have a troble with my stearing servo. The arm is broken because not enough movement for the front axle. First I made an new control tube not the cheap alu. I did it in V2A
Than I thought about the construktion and found out, that I have to make parts the way that the servo can move together with the front axle.
- Chang
Hi Florian,
Saw that little jack on your second last photo today. Very cute.
Lerh Chang
Lerh Chang
Hello Chang,
yes it is verry good for doing things at the terain. It lift about 75kg
