MG flash
- Has liked: 2519 times
- Been liked: 444 times
MG flash
I'm currently trying to wire in my MG flash on a 2012 Tiger fitted with recoil anyone know where the wires should be attached, can't find any reference in the build manuals.
- Has liked: 1481 times
- Been liked: 1687 times
Re: MG flash
The MG LED connects into the audio system, so it depends on which module you have.
On the Amplifier Module, it should be connected to the centre and left hand connections of the three pin plug next to the volume control, with the LED anode to the centre pin and the cathode to the left hand pin
On the Audio Module, it should be connected to the LED2 connection, with the LED anode to the lower pin and the cathode to the upper pin.
There is a resistor built into the TBS5 LED output but you will need to include one if the sound system uses the TBS Mini.
The TBS Mini may also need to be configured to flash the LED output when the MG sound is played. I can undertake this reprogramming for a nominal fee.
