spocket removal
michael didonato
Been liked: 4 times
spocket removal
Post by michael didonato »
can someone tell me how to remove the drive spocket on a late tiger..it has some kind of angle bushing
Dale jordan
Been liked: 525 times
Post by Dale jordan »
Michael . Remove the two grub screws from the taper bush . Then put one of the grub screws in the other threaded hole .. Which is the release hole then tighten this one up . next put a flat screw driver in the slot and give it a tap with a small hammer . The sprocket should then come off . Dale
Nigel Allen
Post by Nigel Allen »
Michael,
I would do the same as Dale said, but without the screwdriver. If you keep turning the grub screw the bush should start to move off the axle and you will be able to remove it.
Nigel.
Garry Coomber
Post by Garry Coomber »
If it doesn't budge or you feel that the you are turning the grub screw to hard, I gentle tap with a soft hammer on the sproket will probaly free things up, especially if the sprocket had been on for a long time.
Garry
1/6 PzKfw III
