Work on the Stowage Bin Tiger 1
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
hi all
The old stowage bin on my Tiger 1 needs an upgrade.
I took it apart, and as you can see on the pictures, it is fairly battleworned :D
Top and bottom parts are bended and twisted, so I took a hammer and gently hammered the parts back to a suitable shape.
Next is to sand and make the surface nice af smooth for the primer.
New hinges will be installed as well as the stowage bin is going to have rivets
More 2 come
cheers
Steen
Has liked: 2282 times
Been liked: 7196 times
Re: Work on the Stowage Bin Tiger 1
I can remember shooting at that stowage bin Steen! I think most of the rnds were LV hollow point 5.56mm :)
Steen Vøler
Has liked: 62 times
that must have been fun Phil :-)
It has served well and there was really no reason for changing it, other than I hade the spare part lying in my parts bin :D
cheers
Steen
Well it has some history Steen, and if you put it in your wood burner for an hour to remove all the filler, then wire brush it and place it on your workshop shelf as a curio people will be fascinated :D
Steen Vøler
Has liked: 62 times
sounds like a plan :D
cheers
Steen
Has liked: 166 times
Been liked: 849 times
I was just going to say that bin looks its been on Phil's gunnery range - as a joke! Sure enough!
Looking forward to seeing it restored.
Steen Vøler
Has liked: 62 times
Here are pictures of the burning process :-)
cheers
Steen
Steen Vøler
Has liked: 62 times
been working a litte bit more on the stowage bin and the base is now finished.
The raised plates for the hinges will be grinded down flat to the surface, as the new hinges has a bend on the to raise the lids.
Will post more pictures as the build comes along
cheers
Steen
Obviously I am watching with interest Steen! Nice work and what a transformation, those rivets make all the difference regards Phil. :D
Steen Vøler
Has liked: 62 times
so its finished - its not perfect, but thinking of the starting point, I am very happy with it.
The last thing to do is to change the hinges to the correct scale and have dem workable
cheers
Steen
Marco Peter
Has liked: 1539 times
Been liked: 798 times
Post by Marco Peter »
Very, very nice. Also have to work on mine, a real rust bucket...
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
looks good from here, a nice detail to add, regards simon manning.
Maarten Schutjes
Been liked: 3 times
Post by Maarten Schutjes »
Nice work Steen!
Steen Vøler
Has liked: 62 times
The logo of the 502 is now painted on the storage bin
cheers
Steen
Steen Vøler
Has liked: 62 times
Finally, after more than 4 months the stowage bin is mounted back to the turret
cheers
Steen
