Centurion smoke grenade tude
David Skeldon
Has liked: 33 times
Been liked: 312 times
Post by David Skeldon »
Hi,
Does any one know the diameter and length of a smoke launcher tube on a Centurion?
Mark Heaps
Has liked: 270 times
Been liked: 327 times
Re: Centurion smoke grenade tude
Post by Mark Heaps »
Presuming they had not changed them between Centurion, Chieftain & Challenger, internal diameter was slightly larger than that of a regular beer can and internal length was also slightly longer than a beer can. :D
The issued tester was fiddly to use so I always made my own. Sand the paint off the external surface of the can to get a good earth contact, hole cut in the bottom for a 5W side-light bulb, hole cut in the side to get the bulb in there. Ring-pull used to pull it easily out of the tube so best to use a sort where the ring-pull stays attached to the can. If ring-pull breaks off then no problem, drink beer and make new tester :D
David Skeldon
Has liked: 33 times
Hi
Thanks for that.best go and buy some beer then.
Has liked: 1481 times
Been liked: 1687 times
Usually helps, I find :lol: :lol:
