I wonder if any of you chaps out there have a spare Trident elevation motor, the shaft on mine is bent although motor works fine.
The long number is 3-30/0524-GS38.0060 I am not convinced that all of that number is relevant to the part I need.
As they say, a picture is worth a thousand words, whoever they are!!
WANTED Trident Tiger 1 gun elevation motor
- Been liked: 3 times
- Has liked: 270 times
- Been liked: 326 times
Re: WANTED Trident Tiger 1 gun elevation motor
I believe the 3-30/0524 refers to the elctric motor whilst the GS38.0060 refers to the gearbox. As the motor still works fine and it is just the output shaft of the gearbox that is bent, you could just replace the gearbox. Trident still stock it and it is also available from RS Components.
Mark, I thank you very much for this info, and I will attempt to chase one down
