Sound Card Exchange
John Pissey
Sound Card Exchange
Post by John Pissey »
Does any know whether a newer Benedini sound card like the TSB mini can be swapped out in the Armortek amplifier. If so is there anything special you need to do differently when installing it?
If you can not install a TSB mini within the amplifier can you bypass the recoil system within the amplifier module and connected it to the TSB mini with a separate amplifier and still have the system function including the recoil?
John
Has liked: 1492 times
Been liked: 1699 times
Re: Sound Card Exchange
I believe there is a daughter board for the TBS Mini for the older Amplifier Modules. Gill will be able to supply pricing.
If you are happy knitting, you could use very short male/female servo extensions to make the relevant connections. You would need to compare the pin outs for the TBS5 and TBS Mini to work out what went where.
John Pissey
Thanks Adrian
I will check with Gill
