Tiger 1 Front hull track hanger
David Stewart
Has liked: 3 times
Been liked: 11 times
Post by David Stewart »
Evening all
Can anyone advise where the best place to acquire a front hull track hanger for a Tiger 1? Or any advice on how to make one please?
Armortek 2010 Mid Tiger 1
Kent Wiik
Has liked: 6 times
Been liked: 194 times
Re: Tiger 1 Front hull track hanger
Post by Kent Wiik »
Hi David,
Field of armor have some:
(scroll down a bit)
http://www.fieldofarmortanks.com/tiger- ... red&page=3
But not that difficult make your own one.
Hope this helped
It´s all in the details!
Has liked: 2282 times
Been liked: 7196 times
Hi David, make one if you can, anyone can buy a piece and revel in the glory (we all do at times) do you have a hardware store or similar? You could try the internet and look for ali stock like "I" beam or "U" sections there's lots of examples out there, just decide on the size/scale. The units in the field often manufactured them from what they could find, so a little research as to your chosen units preference might be worthwhile regards Phil
Robin Ellis
Been liked: 8 times
Post by Robin Ellis »
I got my 'U' channel form B & Q :)
Has liked: 1038 times
David, as Phil implied, the hull track hangar was never a production fitting on the Tiger. Units made up their own style, which is why in Kent's posting, FoA have a few options. If you're not doing a specific vehicle, you could use any of them but the channel section would be strongest. Otherwise, you'll need to look at a photo of the specific tank or unit you've chosen to get the right pattern.
I wouldn't rely on glue to retain it, given the weight of the track links. You could use countersunk set screws. Unless your up to tapping, it's probably OK to drill and glue the screws into the hull. Assuming you've used brass for the hangar, my preferred method would be to silver solder a short section of brass rod at each end and then drill and glue. That way the fixing is invisible and you can then simulate the welds at either end.
David Stewart
Has liked: 3 times
Hi all
Thanks for the feed back from my research on PzAbt 507 I am either not fitting one or going to use a long bar thin bar.
From what I can see the crews welded it on the hull so I might see if I can drill and tap as suggested or drill through and epoxy in place.
Thanks again for your input
