Steel Wheel Bolting
Mike Cooper
Steel Wheel Bolting
Post by Mike Cooper »
Can anyone help me on this one.
I'm looking to detail the steel wheels on my Late Tiger and need to know the sizes of the various bolts required and also a supplier.
If you take a look at David Gray's picture (IMG_0384) you will see what is required (follow the link below). Excellent job by the way David (if you're reading this, get in touch as you are the man).
http://www.armortek.co.uk/gallery/main. ... OISSES_PMT
Mike
David Gray
Been liked: 1 time
Post by David Gray »
hello Mike you can get the nuts and bolts from ekp suppliers
go one the on the armortek owners forum and click on the nuts and bolts topic , and there is a direct link to ekp.
you will need
6BAx3/4 with one size smaller head for the outer wheels
6BA full nuts with one size smaller head for all the wheels
8x6bA threaded rod [ 12" long] for the inner wheels cut into 33mm lengths
1 set of long reach 6BA taps
9BA x3/8 for the locking tabs onthe center hub bolt.s
M3 x12 for the outer bolts on all the wheels
the center bolt is M6x10with the head machined down
regards Dave :D
Mike Cooper
Brilliant David, many thanks for all that information.
Mike
Tim McCarthy
Been liked: 31 times
Post by Tim McCarthy »
G'day Dave
I have never heard of
Is this a small scale dimension fond in hobby shops?
I went to our local Nuts and Bolts supplier and they looked at me as if I was nuts :roll:
Any advice would be greatly appreciated
David Gray
Been liked: 1 time
Hi Tim , these are standard nuts and bolts , but instead of having
a head size to fit a 6BA spanner they have the next size down
head size of 7BA these look more realistic and ekp supplies do
a range of these look on there web site and you will see these
in there catalouge
Dave :D
