Setting the suspension shaft technique late tiger?
Tim McCarthy
Been liked: 31 times
Post by Tim McCarthy »
G'day Fellows
I am setting the suspension arms on my late tiger and I an curious as to what technique did you use to set the suspension arm angle in relation to marking ,filling, milling to get all the first 6 arms at the same angle?
Roland Mann
Been liked: 19 times
Post by Roland Mann »
Hi Tim,
there is a topic "tiger suspension" in this section. It tells you everthing you like to know. Good luck and best regards from an early Tiger man
Roland
Der Weg ist das Ziel.
Dale jordan
Been liked: 525 times
Post by Dale jordan »
Hello Tim .. Here is a photo of the jig that I made out of scrap timber . when you have work out the height of the hole in the jig to give the correct angle clamp the torsion bar in a vice and file the end parrel to your bench . the flat should be 20mm long 3mm wide .
Dale jordan
Tim this is how the other end should look . Tim notice how the flat tapers back to the round of the torsion bar .
Dale jordan
Tim good news I have just found my long lost CD showing all my early mod's on my tiger . So today I will make you and Adrian a copy and post them off to you both . Dale
Has liked: 1495 times
Been liked: 1699 times
That's great Dale - many thanks :D :D
That's an ingenious rig for setting the angle and yet beautifully simple.
It hadn't occured to me until recently that the angle of the axle end will be unknown until it has been screwed into the swing arm. I had assumed I could just file the flats at set angles on the torsion bars :shock:
Dale jordan
Adrian one more tip for you !! Have a look at the photo above see the torsion bar axle with the big blob on it . I removed all of them a turned them down on my lathe to the same dia as the radius of the cast Drop arm . I carnt remember why It was a while ago .. I think it hit the next wheel or something . I'm at home tonight , when I go to work tommorow I will post a photo . let me know if this will help . One thing I know was it was a pain to strip my running gear down to re- do it , I wish someone had told me about it .. Dale
Tim McCarthy
G'day Dale
Thanks for the CD. :D
I will study next week.
Once you had done yours was each axle perfect or what variants did you have?
Allan Richards
Been liked: 10 times
Post by Allan Richards »
Tim,
Here are the pictures of the jig I made, which I hope are fairly self explanatory. The jig only took an hour to make but it guarranttees that each bar is ground to the same angle.
Allan Richards
Tim McCarthy
Thanks Alan for the reply.
Thanks Roland for the referral link.
From yourself and Dale I have made a temp jig but something is not right as when I put them in the angles are changing 2 degrees plus or minus.
Should i get the angle close then slight file to get perfect.
willie leonard
Been liked: 11 times
Post by willie leonard »
Thanks Gentlemen! for the insite about filing the torsion bar flats.I had no idea how to get all of them exact,and your pictures of the custom jigs were just what I needed.I just spent the last three hours going through my jadgpanther manual and I know this will not be my last inquiry.
