Now it was time to make some thoughts about the control board. At my Jagdtiger I use the back door of the casemate to hide my control board; in my opinion a useful, practice-approved solution. Therefore I decided to do the same at my Jagdpanther.
First of all a little frame was needed to hold the board, because some space is necessary for the lever of the circuit breaker. I use aluminium scrap parts which are available for low cost:
Because the model is finshed already, I have to hide all new drilling holes behind available fittings as fire extinguisher, hinges and so on (the pic shows a test mounting before sluring the frame):
Here the board ist mounted (without wiring):
Fraom left to right you see the main circuit breaker, below it a fuse holder for the steering circuit, above three LEDs to indicate voltages and switch states, below 'dollhouse' pushbuttons to switch my 100 amps bistable relays in the main power circuits and right a switch to activate the sound module. Right to the bottom are the sockets for loading 2 lead silicone akkus in series with a middle tap to load them individual. LiFePO4 cells are rather expensive today, therefore I will test these silicone batteries which are extremely resistant in cycle use (up to 300 cycles at 100 % DoD!). If this is true, I could use them about 150 years due to my operation conditions!
This arrangement allows me to control the whole tank, the driving without sounds (e.g. for transport) and the use of the sound without activated motion possibilities. The USM-RC2 sound module has an option of background musics (controlled by RC) giving hours of songs for entertainment in 'pauses in the fighting'
. It is an additional safety when there is no possibility for the model to move unwanted.
