Mg flash with audio module
David Gray
Been liked: 1 time
Post by David Gray »
Just connected up all the motion pack ,and everything seems to work apart from the mg
Flash . I am using the 3 potion toggle switch on a futaba 7c to control the sound
When I turn the sound unit on and the engine start sound the mg starts to flash strait
Away and goes to a solid on when I move the stick to accelerate, I have the mg connected
To output 4 on the module ,and tried programmING the unit several times. As any one else had the same problem
Regards Dave gray :?
Mark Heaps
Has liked: 270 times
Been liked: 327 times
Re: Mg flash with audio module
Post by Mark Heaps »
I haven´t got to that stage in my build yet but my research indicates that output 6 rather than output 4 is the one that should be used.
David Gray
Been liked: 1 time
Hi mark , reading the instructions, it says 123 are for advanced users to program
,4 is mg flash and 567 are for the recoil option , I will try using the other outputs
To see if works dave :D
Mark Heaps
Has your audio module got the benedini TBS5 or TBS-mini ?
I was presuming the TBS5.
David Gray
Been liked: 1 time
Hi mark , it's the tbs mini , I think it's the latest audio module
Dave
Been liked: 3683 times
Hello David
Firstly my apologies for the delay in responding.
You have the latest Audio module and TBS Mini sound card setup in your new kit. It is very different from previous releases.
I have, this morning, been testing the the TBS Mini cards and checking the parameters.
The machine gun flash is connected via the audio board direct to LED output 4 on the board.
The outputs are are labelled and the instructions show you where these connections are.
All the boards, 5 off them, work fine when an LED is connected to output 4. The setting up of the TBS Mini, that the user has to do, does not affect this function at all.
Double check that you understand which is the correct output on the audio module and that you have the LED connected the correct way round.
David Gray
Been liked: 1 time
Hi Mark I will check this again , but it is
Hard to get this wrong as the led outputs
Are clearly marked on the case 1to 7
And I have tried the plug on the led both ways
I will let you know how I get on when I get back from
Holiday
Regards David
David Gray
Been liked: 1 time
Hi mark , I still can't get the mg flash to work , when I turn on the audio module with the
Toggle switch on the transmitter the mg led starts to flash strait Away with the engine start up and stops when the modual is turned off this is a picture of the mg connected to the sound card.can you confirm this is correct
Thanks David
Has liked: 1475 times
Been liked: 1674 times
Try it on LED1.
David Gray
Been liked: 1 time
Hi Adrian ,yes that's it , works fine now , but why do sent it work on number 4
Mark has tried 5 units and they all work on number 4 ?
Thanks Adrian , dave
