Idler parts
Has liked: 1484 times
Been liked: 1687 times
Idler parts
Included with my Early Tiger I seem to have two almost complete sets of track tensioning parts.
The only difference I can see is that on one set of tensioner arms (CE0312), there is a thread on one side where the axle passes through and the other side is not drilled. On the other set the hole passes through both sides of the arm and neither side is threaded.
Can anyone remember which is the correct style part and if there were any other differences/corrections made to the Early idler parts :?:
<Later...>
Just found the article in the old Forum entitled "Tiger Idler Tension Arm" which seems relevant and advocates three possible solutions, one of which is to drill through the arm, so I'll use the drilled through arms and discard the others.
Still interested in why I have so many duplicated parts... :?:
David Pengelly
Been liked: 2 times
Post by David Pengelly »
" Old forum " , can you give me the link please Adrian , as ive not been able to access it.
thanks in antisipation, Dave
Was die Hölle das war
David, the URL is:
http://www.daventrynet.co.uk/forum
