Power Cutoff switch
michaelthompson
Been liked: 8 times
Power Cutoff switch
Post by michaelthompson »
Hi Guys, now at the electric fitting stage on 131. I want to have an on/off switch that will totally depower the complete system. Not being a wiggly amps guru I was hoping someone could advise me on the type of switch to use. Thanks in advance Mick
Steve Stuart
Has liked: 256 times
Been liked: 187 times
Re: Power Cutoff switch
Post by Steve Stuart »
Following the recommendation of John Davie I have fitted a 24V High Amp relay. This works well as I have Fiefel Tubes fitted and that blocks the normal hatch access route. I have all the switches to operate the Power Module, Smoker and Relay under the Snorkel Hatch.
I have a remote momentary switch connected to the Power Module now fitted to all my Tanks so that I can get to turn the Tank off quickly from a relatively easy to access location. I believe I have a posting about this but cannot track it down!
