Setting Suspension Angle
Posted: Sat Feb 20, 2016 10:49 pm
by michaelthompson
Hi Gents
what is the best/easiest method for setting suspension angle to maintain accuracy
mick
Re: Setting Suspension Angle
Posted: Sun Feb 21, 2016 2:01 pm
Hi Mick.
If you check about two thirds of the way down this thread from Stephen White, you'll see him setting the angle with a protractor head.
http://www.armortek.co.uk/Forum3b/viewt ... 970&p=8082
Before the introduction of the adjustable torsion bar suspension, it was necessary to grind flats onto the torsion bars to set the angle, but now you just need to get the arms at the correct angle and tighten down the fixed end.
Posted: Sun Feb 21, 2016 5:07 pm
by michaelthompson
Cheers Adrian :D
