Setting Suspension Angle
michaelthompson
Been liked: 8 times
Post by michaelthompson »
Hi Gents
what is the best/easiest method for setting suspension angle to maintain accuracy
mick
Has liked: 1365 times
Been liked: 1564 times
Re: Setting Suspension Angle
Hi Mick.
If you check about two thirds of the way down this thread from Stephen White, you'll see him setting the angle with a protractor head.
http://www.armortek.co.uk/Forum3b/viewt ... 970&p=8082
Before the introduction of the adjustable torsion bar suspension, it was necessary to grind flats onto the torsion bars to set the angle, but now you just need to get the arms at the correct angle and tighten down the fixed end.
michaelthompson
Been liked: 8 times
Cheers Adrian :D
