I've noticed that in my collection of jerry cans, I have the usual Dragon Wehrmacht and USMC types but I also seem to have two of another type.
Thay have the same sort of X on the side as the US ones except the ends taper to a point instead of being rounded. The biggest difference is that the filler cap seems to be a clamp fit instead of a screw fit.
Are these WWII vintage or a more later design ? Or are they from a different manufacturer ?
Jerry can types
- Has liked: 1480 times
- Been liked: 1685 times
- Been liked: 177 times
HI Adrian
I believe the ones you are describing are also Dragon-Models. I would guess they are water cans(just a guess). They came with the same sets as the USMC ones that have the threaded cap with wire twist teather. if I remember right.
some info
http://www.olive-drab.com/od_mvg_jerry_can.php
some info
- Been liked: 3694 times
